Hi all,
I’m running the LCD test programs supplied with the board and occasionally (1 time out of 3) the LCD doesn’t initialise after reset / powerup - ie. no display. The program carries on running and everything else works fine (buttons, beeps, LED etc).
I’m using Rowley Crossworks to compile / upload by JTAG and have also ported the IAR EW example across to see if there is a code problem, but the other example does the same :s
Does anyone know where this could be coming from? Could it be a bad board / LCD? Maybe it’s a timing issue?
Also when I compile in release, the whole thing goes crazy, but that’s another problem…
Thanks.
Ben.
