Right my apologies for not posting the error messages, so from the begining.
im using eclipse 3.2.
olimex LPC2378STk dev board with arm-ocd-tinyusb
Build works fine :-
make -k all
“.assembling”
arm-elf-as -ahls -mapcs-32 -o crt.o crt.s > crt.lst
“.compiling”
arm-elf-gcc -I./ -c -fno-common -O0 -g main.c
“…linking”
arm-elf-ld -v -Map main.map -Tdemo2106_blink_flash.cmd -o main.out crt.o main.o
GNU ld version 2.16.1
“…copying”
arm-elf-objcopy -O binary main.out main.bin
arm-elf-objdump -x --syms main.out > main.dmp
connection to arm-ocd =
Info: openocd.c:82 main(): Open On-Chip Debugger (2006-10-12 18:00 CEST)
hit debug and :-
Error: armv4_5.c:186 armv4_5_mode_to_number(): invalid mode value encountered
Error: arm7_9_common.c:972 arm7_9_debug_entry(): cpsr contains invalid mode value - communication failure
Warning: arm7_9_common.c:623 arm7_9_poll(): DBGACK set while target was in unknown state. Reset or initialize target before resuming
and at other times :-
~“Ignoring packet error, continuing…\n”
Malformed response to offset query, timeout
&“Malformed response to offset query, timeout\n”
6^done
(gdb)
7 monitor sleep 500
&“monitor sleep 500\n”
&“"monitor" command not supported by this target.\n”
monitor sleep 500
“monitor” command not supported by this target.
7^done
(gdb)
8 monitor poll
&“monitor poll\n”
monitor poll
8^done
(gdb)
9 monitor flash probe 0
&“monitor flash probe 0\n”
9^done
(gdb)
10 monitor flash erase 0 0 0
&“monitor flash erase 0 0 0\n”
10^done
(gdb)
11 monitor flash write 0 main.bin 0x0
&“monitor flash write 0 main.bin 0x0\n”
11^done
(gdb)
12 monitor reset run
&“monitor reset run\n”
monitor reset run
12^done
(gdb)
13 monitor sleep 500
monitor sleep 500
13^done
(gdb)
14 monitor soft_reset_halt
&“monitor soft_reset_halt\n”
14^done
(gdb)
15 monitor arm7_9 force_hw_bkpts enable
&“monitor arm7_9 force_hw_bkpts enable\n”
15^done
(gdb)
16 symbol-file main.out
&“symbol-file main.out\n”
&“main.out: No such file or directory.\n”
16^done
(gdb)
17 thbreak main
thbreak main
No hardware breakpoint support in the target.
&“thbreak main\n”
&“No hardware breakpoint support in the target.\n”
17^done
(gdb)
18 continue
continue
The program is not being run.
&“continue\n”
&“The program is not being run.\n”
18^done
(gdb)
19-stack-list-frames
&“No registers.\n”
19^error,msg=“No registers.”
(gdb)
20-break-list
No registers.
20^done,BreakpointTable={nr_rows=“0”,nr_cols=“6”,hdr=[{width=“3”,alignment=“-1”,col_name=“number”,colhdr=“Num”},{width=“14”,alignment=“-1”,col_name=“type”,colhdr=“Type”},{width=“4”,alignment=“-1”,col_name=“disp”,colhdr=“Disp”},{width=“3”,alignment=“-1”,col_name=“enabled”,colhdr=“Enb”},{width=“10”,alignment=“-1”,col_name=“addr”,colhdr=“Address”},{width=“40”,alignment=“2”,col_name=“what”,colhdr=“What”}],body=}
(gdb)
21 info program
&“info program\n”
~“The program being debugged is not being run.\n”
21^done
(gdb)
22-environment-directory /cygdrive/C/GCCFD/projects/lpc2148 /cygdrive/C/GCCFD/projects/lpc2148/.settings
22^done,source-path=“/cygdrive/C/GCCFD/projects/lpc2148:/cygdrive/C/GCCFD/projects/lpc2148/.settings:$cdir:$cwd”
(gdb)
23 info threads
&“info threads\n”
&“No registers.\n”
23^done
(gdb)
24-stack-info-depth
No registers.
&“No registers.\n”
24^error,msg=“No registers.”
(gdb)
25-data-list-register-names
25^done,register-names=[“r0”,“r1”,“r2”,“r3”,“r4”,“r5”,“r6”,“r7”,“r8”,“r9”,“r10”,“r11”,“r12”,“sp”,“lr”,“pc”,“f0”,“f1”,“f2”,“f3”,“f4”,“f5”,“f6”,“f7”,“fps”,“cpsr”]
(gdb)
26-stack-info-depth
No registers.
&“No registers.\n”
26^error,msg=“No registers.”
(gdb)
27-stack-info-depth
No registers.
&“No registers.\n”
27^error,msg=“No registers.”
(gdb)
28-data-list-changed-registers
&“No registers.\n”
No registers.
28^error,msg=“No registers.”
(gdb)
29-stack-info-depth
&“No registers.\n”
No registers.
29^error,msg=“No registers.”
(gdb)
30-stack-info-depth
&“No registers.\n”
30^error,msg=“No registers.”
(gdb)
31-stack-info-depth
No registers.
No registers.
&“No registers.\n”
31^error,msg=“No registers.”
(gdb)
any help/pointers would be greatly appreciated.
