Olimex STR-P711 and GCC
I have tried to get the following project to compile and work on an
Olimex STR-P711 with gcc. It’s the STR71xLibrary rtc example hacked
for the above board from the the examples. If I build this example as
distributed with EWARM, it works.
I then took the C files, added the STR71x .S files for gcc and the .ld
files and built it with WinARM-20060606. The resulting bin file does
not work. As a newbie, I am completely stumped.
Does anyone have a suggestion as to where the problem may lie?
Jeremy
Sorry - files are at:
http://www.maccelari.com/rtc.zip
