hi,
I just got in 2 of the “One Wire Digital Temperature Sensor - DS18B20” from sparkfun… but no matter what i do i cant seem to make it work with arduino. If some has used these sensors or know how to hook up a One Wire sensor, please reply. ![]()
I tried using the onewire.h module with both with and without the parasite mode… and the data pin was connected to the micro controller using a 4.7K resistor. However when i run the module, the module never finds the sensor and replies with “No addresses found”.
*One Wire sensors allow multiple sensors to communicate by connecting all to the same pin and differentiation is based on their unique id.
Thanks to all in advance.
