I’ve tried alot to bring up my board with the OOCD and Olimex JTAG, but it doesn’t work. Can somebody explane the problem and help me to solve it?
I installed the OOCD in it works with the Olimex Dev-Board STM32-P103. It also works on my board with an medium density chip but on my new one it doesn’t work I got follow messages:
Open On-Chip Debugger 0.3.1 (2009-11-13-16:13)
$URL$
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
10 kHz
jtag_nsrst_delay: 1000
jtag_ntrst_delay: 1000
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
force hard breakpoints
Info : clock speed 10 kHz
Info : JTAG tap: stm32.cpu tap/device found: 0x9de00477 (mfg: 0x23b, part: 0xde00, ver: 0x9)
Warn : JTAG tap: stm32.cpu UNEXPECTED: 0x9de00477 (mfg: 0x23b, part: 0xde00, ver: 0x9)
Error: JTAG tap: stm32.cpu expected 1 of 1: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Warn : TAP stm32.bs does not have IDCODE
Warn : JTAG tap: stm32.bs UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
Error: JTAG tap: stm32.bs expected 1 of 5: 0x06412041 (mfg: 0x020, part: 0x6412, ver: 0x0)
Error: JTAG tap: stm32.bs expected 2 of 5: 0x06410041 (mfg: 0x020, part: 0x6410, ver: 0x0)
Error: JTAG tap: stm32.bs expected 3 of 5: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Error: JTAG tap: stm32.bs expected 4 of 5: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Error: JTAG tap: stm32.bs expected 5 of 5: 0x06418041 (mfg: 0x020, part: 0x6418, ver: 0x0)
Warn : Unexpected idcode after end of chain: 33 0xe2d04010
Warn : Unexpected idcode after end of chain: 65 0xc000001f
Warn : Unexpected idcode after end of chain: 97 0x8000003f
Warn : Unexpected idcode after end of chain: 129 0xc000003f
Warn : Unexpected idcode after end of chain: 161 0x8000003f
Warn : Unexpected idcode after end of chain: 193 0x8000007f
Warn : Unexpected idcode after end of chain: 225 0xc000003f
Warn : Unexpected idcode after end of chain: 257 0x8000003f
Warn : Unexpected idcode after end of chain: 289 0x8000007f
Warn : Unexpected idcode after end of chain: 321 0x8000007f
Warn : Unexpected idcode after end of chain: 353 0xc000003f
Warn : Unexpected idcode after end of chain: 385 0x8000003f
Warn : Unexpected idcode after end of chain: 417 0x8000007f
Warn : Unexpected idcode after end of chain: 449 0xc000003f
Warn : Unexpected idcode after end of chain: 481 0x8000003f
Warn : Unexpected idcode after end of chain: 513 0xc000003f
Warn : Unexpected idcode after end of chain: 545 0xc000001f
Warn : Unexpected idcode after end of chain: 577 0x8000003f
Error: double-check your JTAG setup (interface, speed, missing TAPs, …)
Warn : Unexpected idcode after end of chain: 33 0xf9642008
Warn : Unexpected idcode after end of chain: 65 0xe0000007
Warn : Unexpected idcode after end of chain: 97 0x8000001f
Warn : Unexpected idcode after end of chain: 289 0xc000003f
Warn : Unexpected idcode after end of chain: 321 0x8000003f
Warn : Unexpected idcode after end of chain: 353 0x8000007f
Warn : Unexpected idcode after end of chain: 385 0x8000007f
Warn : Unexpected idcode after end of chain: 449 0x8000007f
Warn : Unexpected idcode after end of chain: 481 0x8000007f
Warn : Unexpected idcode after end of chain: 513 0x8000007f
Warn : Unexpected idcode after end of chain: 545 0xc000003f
Warn : Unexpected idcode after end of chain: 577 0xc000001f
The hardware should be ok because I’ve test the connection with the Hitex JTAG, currently I switch to this tool but it is no way I want to use the OOCD.
Cheers,
Christian
