OpenLog Artemis Data Logging Issues
I recently bought an OpenLog Artemis for the IMU. Although I was able to generally get good data, I have recently run into an issue where the serial monitor will note that the microSD card is connected, and that it is writing to DataLog00057.txt, when I unplug the OLA and look at the files on the microSD card, I do not see DataLog00057.txt. It was working fine previously.
Furthermore, when I tried to delete everything from the microSD card to try and start from scratch, plugging the microSD card into the OLA returned all the files to the card.
Could someone help me navigate this? I would like to be able to record data to the SD card again.
Tolik
My apologies for two posts in a row, figured since they were different issues I should separate them.
You could wipe/format the SD card and try again OpenLog Artemis Hookup Guide - SparkFun Learn
If it’s still giving issues afterward you can open the SD card on a PC to read it and take a look at the settings files and see what logfile # it’s attempting to create and adjust that #
This was helpful, thank you! Issue was simply that the sdcard was corrupted in some sort of way - would not format no matter what I did. Got a new card and it is great.
