Hi!
I have an OpenLog Artemis which I was planning to use with an MPR0025PA MicroPressure Sensor. The first time I used the system I was able to get data, but afterward, the blue LED on the Artemis turned off and since then I haven’t been able to make the sensor work.
I tried to load the latest OLA firmware with the Artemis Firmware Upload GUI, and that turned the blue LED back on, but once I open the serial monitor the Artemis is unable to detect the sensor. Is there any way to reset the Artemis back to the initial setup (apart from the RST bottom)?
Thank you!
