Thanks for the update. I’m glad the new card is working for you.
If you try the Kingston card in your PC, it may work OK. It just needs more current on start-up (the in-rush) than the OLA can provide. The in-rush varies considerably from card to card.
If you want to return the Kingston card, please submit an RMA request and add a link to this forum issue in the “Why do you want an RMA?” section. Apologies for the inconvenience!
https://www.sparkfun.com/returns
