Openlog for numeric data
I am using the openlog to store data using a TI mcu. I am able to log text without any problems. However, I require to log floating point values and would like to avoid the use of sprint() to convert numbers to strings.
I saw some forums mentioning the use of file as a binary file (or as a CSV file) but I could not find any documentation as to how to do it.
It would be extremely helpful if someone could guide me how to do this.
The OpenLog will log any serial data you send it, but you will need to consult the documentation for your TI mcu to figure out how to output a floating point number serially. If you can output it, the OpenLog will save it to a SD card.
