almost 1 week reading and googling, and result is almost 0 :s, i trying to make the configuration script to be able to erase, write… the flash chip.
i have olimex SAM9261 board, and openocd 2,3,4 ( with all 3 versions result is the same).
looks i have troubles to make setting with NAND flash, looks AT91SAM9261 is not supported, so i tested with AT91SAM260 setting and i got this error:
Error: unknown NAND flash device found, manufacturer id: 0x0a device id: 0x0a
probing failed for NAND flash device
Can someone tell me if i loosing time because is not supported chipset or if something exist but i didnt seen ?
Regards,
