Has anyone been able to use the OpenOCD environment to program the flash in the LPC2368 processors?
I have tried the parport wiggler clone and the Olimex ARM-USB-OCD adapter with the Eclipse/OpenOCD environment. I can download and debug out of Ram as well as debug out flash using the Flashmagic tool to download the code. I have tried changing the flash bank speed setting and jtag_speed, as well as using rev1.15 and 1.30 but I still get the same results.
Info: openocd.c:84 main(): Open On-Chip Debugger (2007-01-31 12:00 CET)
Warning: embeddedice.c:175 embeddedice_build_reg_cache(): EmbeddedICE version 7 detected, EmbeddedICE handling might be broken
Warning: arm7_9_common.c:842 arm7_9_halt(): target was already halted
Info: server.c:67 add_connection(): accepted ‘gdb’ connection from 0
Warning: gdb_server.c:195 gdb_put_packet(): negative reply, retrying
Error: gdb_server.c:213 gdb_put_packet(): unknown character 0x24 in reply, dropping connection
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x5a
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x31
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x2c
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x35
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x33
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x34
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x23
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x62
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x76
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x43
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x6f
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x6e
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x74
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x3f
Warning: gdb_server.c:256 gdb_get_packet(): ignoring character 0x39
Warning: gdb_server.c:246 gdb_get_packet(): acknowledgment received, but no packet pending
