I am trying to flash lpc2368 (which has a 12MHz external oscillator, and 4MHz internal oscillator) with openocd-0.7.0. But it works only on second attempt. Here are the logs for successful flashing and failed flashing (Differences in the log output is shown in red fonts):
Failed:
Open On-Chip Debugger 0.5.0 (2011-08-09-23:26)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
Info : only one transport option; autoselect ‘jtag’
init_targets
SETUP OPENOCD ---------------------------------------------
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
500 kHz
debug_level: 2
dcc downloads are enabled
fast memory access is enabled
adapter_nsrst_delay: 200
jtag_ntrst_delay: 200
RESET DEVICE ----------------------------------------------
Info : clock speed 500 kHz
Info : JTAG tap: lpc2368.cpu tap/device found: 0x4f1f0f0f (mfg: 0x787, part: 0xf1f0, ver: 0x4)
Info : Embedded ICE version 7
Error: EmbeddedICE v7 handling might be broken
Info : lpc2368.cpu: hardware has 2 breakpoint/watchpoint units
target state: halted
target halted in ARM state due to debug-request, current mode: System
cpsr: 0x8000005f pc: 0x00006f84
cpsr: 0x8000005f pc: 0x00006fa0
requesting target halt and executing a soft reset
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x800000d3 pc: 0x00000000
flash ‘lpc2000’ found at 0x00000000
FLASH INFO ------------------------------------------------
#0 : lpc2368.flash (lpc2000) at 0x00000000, size 0x0007e000, buswidth 0, chipwidth 0
UNPROTECT FLASH -------------------------------------------
cleared protection for sectors 0 through 27 on flash bank 0
ERASE FLASH -----------------------------------------------
cpsr: 0x8000005f pc: 0x00006fbc
erased sectors 0 through 27 on flash bank 0 in 0.078000s
successfully checked erase state
0: 0x00000000 (0x1000 4kB) erased
1: 0x00001000 (0x1000 4kB) erased
2: 0x00002000 (0x1000 4kB) erased
3: 0x00003000 (0x1000 4kB) erased
4: 0x00004000 (0x1000 4kB) erased
5: 0x00005000 (0x1000 4kB) erased
6: 0x00006000 (0x1000 4kB) erased
7: 0x00007000 (0x1000 4kB) erased
8: 0x00008000 (0x8000 32kB) erased
9: 0x00010000 (0x8000 32kB) erased
10: 0x00018000 (0x8000 32kB) erased
11: 0x00020000 (0x8000 32kB) erased
12: 0x00028000 (0x8000 32kB) erased
13: 0x00030000 (0x8000 32kB) erased
14: 0x00038000 (0x8000 32kB) erased
15: 0x00040000 (0x8000 32kB) erased
16: 0x00048000 (0x8000 32kB) erased
17: 0x00050000 (0x8000 32kB) erased
18: 0x00058000 (0x8000 32kB) erased
19: 0x00060000 (0x8000 32kB) erased
20: 0x00068000 (0x8000 32kB) erased
21: 0x00070000 (0x8000 32kB) erased
22: 0x00078000 (0x1000 4kB) erased
23: 0x00079000 (0x1000 4kB) erased
24: 0x0007a000 (0x1000 4kB) erased
25: 0x0007b000 (0x1000 4kB) erased
26: 0x0007c000 (0x1000 4kB) erased
27: 0x0007d000 (0x1000 4kB) erased
PROGRAM FLASH ---------------------------------------------
wrote 55304 bytes from file IMO-USB2.elf in 2.418004s (22.336 KiB/s)
VERIFY FLASH ----------------------------------------------
address 0x00000000 length 0x0000d6b8
address 0x0000d6b8 length 0x00000150
verified 55304 bytes in 0.000000s (inf KiB/s)
0: 0x00000000 (0x1000 4kB) not erased
1: 0x00001000 (0x1000 4kB) not erased
2: 0x00002000 (0x1000 4kB) not erased
3: 0x00003000 (0x1000 4kB) not erased
4: 0x00004000 (0x1000 4kB) not erased
5: 0x00005000 (0x1000 4kB) not erased
6: 0x00006000 (0x1000 4kB) not erased
7: 0x00007000 (0x1000 4kB) not erased
8: 0x00008000 (0x8000 32kB) not erased
REBOOT DEVICE ---------------------------------------------
target halted in ARM state due to breakpoint, current mode: Supervisor
cpsr: 0x40000053 pc: 0x40000070
cpsr: 0x400000d3 pc: 0x00000000
shutdown command invoked
Passed:
init_targets
500 kHz
debug_level: 2
target halted in Thumb state due to debug-request, current mode: Supervisor
cpsr: 0x200000f3 pc: 0x7fffe15a
cpsr: 0x200000d3 pc: 0x00000020
cpsr: 0x200000d3 pc: 0x00000000
cpsr: 0x200000d3 pc: 0x0000004c
erased sectors 0 through 27 on flash bank 0 in 0.093600s
# 0: 0x00000000 (0x1000 4kB) not erased
wrote 55304 bytes from file IMO-USB2.elf in 2.527204s (21.371 KiB/s)
cpsr: 0x400000d3 pc: 0x40000070
The config file is :
# Flash LPC2368 memory using openocd
# and a FTDI FT2232-based JTAG-interface
source [find olimex-arm-usb-tiny.cfg]
source [find openocd-cpu-lpc2368.cfg]
proc init_targets {} {
echo ""
echo ">> SETUP OPENOCD ---------------------------------------------"
# setup_lpc2368 <core_freq_khz> <adapter_freq_khz>
setup_lpc2368 4000 500
debug_level 2
arm7_9 dcc_downloads enable
arm7_9 fast_memory_access enable
jtag_nsrst_delay 200
jtag_ntrst_delay 200
echo ""
echo ">> RESET DEVICE ----------------------------------------------"
init
halt 100
reset
sleep 10
soft_reset_halt
sleep 10
flash probe 0
echo ""
echo ">> FLASH INFO ------------------------------------------------"
flash banks
echo ""
echo ">> UNPROTECT FLASH -------------------------------------------"
sleep 10
#flash protect num first last ('on'|'off')
flash protect 0 0 last off
echo ""
echo ">> ERASE FLASH -----------------------------------------------"
sleep 10
reset halt
#flash erase_sector num first last
flash erase_sector 0 0 last
sleep 10
flash erase_check 0
echo ""
echo ">> PROGRAM FLASH ---------------------------------------------"
sleep 10
halt 100
#flash write_image [erase] [unlock] filename [offset] [type]
flash write_image IMO-USB2.elf
echo ""
echo ">> VERIFY FLASH ----------------------------------------------"
sleep 10
#test_image filename [address ['bin'|'ihex'|'elf']]
test_image IMO-USB2.elf
flash erase_check 0
echo ""
echo ">> REBOOT DEVICE ---------------------------------------------"
init
halt 100
reset
sleep 10
soft_reset_halt
sleep 10
resume
sleep 10
shutdown
I cannot get what is the problem. Has anybody any idea?
