Openocd on i.MX6 quad seems to disconnect from the target when the linux kernel loads.
I get a lot of “cortex_a_mmu: target not halted” errors.
I have tried other jtag speeds (500 - 25000), on all of them I get the same error.
To reproduce I am doing the following:
start openocd
start target
target is halted by openocd script
connect gdb on localhost:3333
run “cont” command on gdb
uboot loads kernel
while kernel boots connection with the target is lost
Does anyone have an ideea of how to debug this ?
openocd configuration: http://pastebin.com/Hsu74SA3
debug output log: http://pastebin.com/YJgqJU5A
Target is an i.MX6 quad, linux Kernel command line has “maxcpus=1”.
openocd --version
Open On-Chip Debugger 0.9.0-dev-00346-g3e1dfdc (2015-03-16-09:37)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
openocd -f paste-bin-cfg.txt
Warn : imx6.sdma: nonstandard IR value
adapter speed: 1000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: imx6.dap tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : TAP imx6.sdma does not have IDCODE
Info : JTAG tap: imx6.sjc tap/device found: 0x2191c01d (mfg: 0x00e, part: 0x191c, ver: 0x2)
Info : imx6.cpu.0: hardware has 6 breakpoints, 4 watchpoints
Info : ttbcr 0ttbr0 8fff0000ttbr1 b2300001
Info : imx6.cpu.0 rev a, partnum c09, arch f, variant 2, implementor 41
Info : number of cache level 1
Info : imx6.cpu.0 cluster 0 core 0 multi core
examine-end event caught: halting target…
Info : accepting ‘gdb’ connection on tcp/3333
Polling target imx6.cpu.0 failed, GDB will be halted. Polling again in 100ms
Warn : target imx6.cpu.0 is not halted
Error: Target not halted
Error: cortex_a_mmu: target not halted
Error: JTAG-DP OVERRUN - check clock, memaccess, or reduce jtag speed
Error: MEM_AP_CSW 0x0, MEM_AP_TAR 0x80000042
Error: MEM_AP_CSW 0x80000042, MEM_AP_TAR 0x82150080
Polling target imx6.cpu.0 failed, GDB will be halted. Polling again in 300ms
Polling target imx6.cpu.0 succeeded again, trying to reexamine
