I try to use the target_script command for initialization after reset:
target_script 0 reset ./myreset.script
This is the response I get from OpenOCD:
Open On-Chip Debugger (2008-02-23 10:00 CET) svn: 320
$URL: http://svn.berlios.de/svnroot/repos/openocd/trunk $
Info: configuration.c:56 configuration_output_handler(): opened configs/str7xx_signalyzer.cfg
Info: jtag.c:1230 jtag_examine_chain(): JTAG device found: 0x3f0f0f0f (Manufacturer: 0x787, Part: 0xf0f0, Version: 0x3)
Warning: arm7_9_common.c:771 arm7_9_assert_reset(): srst resets test logic, too
The script does not get execute. If I purposely changed my target_script to the following:
target_script 1 reset ./myreset.script
The OpenOCD complains:
x_signalyzer.cfg
Error: target.c:1213 handle_target_script_command(): target number ‘1’ not defined
Something is broken regarding on the “target_script” command?
The OpenOCD R320 distribution is from YAGARTO.
Regards,
Lawrence
