Hi.
I have installed OpenOCD and copied f parport.cfg and lpc2103.cfg to my project directory. I have modified the parallel port address to match my port address.
When I type
openocd -d -f parport.cfg -f lpc2103.cfg
I get the following:
Info: openocd.c:93 main(): Open On-Chip Debugger (2007-09-05 09:00 CEST)
Info: configuration.c:50 configuration_output_handler(): Command if not found
Info: configuration.c:50 configuration_output_handler(): Command set not found
Info: configuration.c:50 configuration_output_handler(): Command } not found
Info: configuration.c:50 configuration_output_handler(): Command jtag not found
Error: target.c:1062 handle_target_command(): target ‘create’ not found
What am Idoing wrong? It doesn’t understand the syntax of the configuration files.
Any ideas?
