Hi all
Does openocd currently support intel xscale processors?
Im trying to debug my pxa270 which Amontec JTAGkey-Tiny and I get some errors and I cant locate the problem.
My configuration file is :
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Amontec JTAGkey A"
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
jtag_nsrst_delay 200
jtag_ntrst_delay 200
jtag_speed 2
#use combined on interfaces or targets that can't set TRST/SRST
#separately
reset_config trst_and_srst trst_pulls_srst
#jtag scan chain
jtag_device 7 0x1 0x7f 0x7e
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target xscale little run_and_halt 0 pxa27x
run_and_halt_time 0 30
and I get the result:
Debug: jtag.c:1246 jtag_init():
Debug: ft2232.c:1243 ft2232_init(): 'ft2232' interface using FTD2XX with 'jtagkey' layout
Debug: ft2232.c:1329 ft2232_init(): current latency timer: 2
Debug: ft2232.c:1492 jtagkey_init(): 80 08 1b
Debug: ft2232.c:1550 jtagkey_init(): 82 09 0f
Debug: ft2232.c:241 ft2232_speed(): 86 02 00
Debug: jtag.c:274 jtag_call_event_callbacks(): jtag event: TRST asserted
Debug: jtag.c:1132 jtag_reset_callback():
Debug: ft2232.c:1126 ft2232_execute_queue(): statemove: 0
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 3):
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 4b 06 7f
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x01ff
Debug: ft2232.c:1181 ft2232_execute_queue(): IR scan, 9 bit, end in 0
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 10):
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 4b 06 1b 39 00 00 ff 6b 06 ff
Info: ft2232.c:375 ft2232_send_and_recv(): inter: 0.0, inter2: 0.0 end: 0.0
Debug: ft2232.c:390 ft2232_send_and_recv(): read buffer (0 retries): 2 bytes
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 81 ff
Debug: jtag.c:1032 jtag_read_buffer(): fields[0].in_value: 0x0181
Debug: openocd.c:101 main(): jtag init complete
Debug: xscale.c:1515 xscale_assert_reset(): target->state: unknown
Debug: jtag.c:274 jtag_call_event_callbacks(): jtag event: SRST asserted
Debug: ft2232.c:939 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: ft2232.c:1044 ft2232_execute_queue(): trst: 1, srst: 1
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 82 00 0f
Debug: ft2232.c:1189 ft2232_execute_queue(): sleep 1000 usec
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 0):
Debug: jtag.c:274 jtag_call_event_callbacks(): jtag event: TRST released
Debug: ft2232.c:939 jtagkey_reset(): trst: 0, srst: 1, high_output: 0x01, high_direction: 0x0f
Debug: ft2232.c:1044 ft2232_execute_queue(): trst: 0, srst: 1
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 82 01 0f
Debug: ft2232.c:1189 ft2232_execute_queue(): sleep 200000 usec
Debug: ft2232.c:1189 ft2232_execute_queue(): sleep 100000 usec
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x09
Debug: ft2232.c:1181 ft2232_execute_queue(): IR scan, 7 bit, end in 8
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x02
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x40010000
Debug: jtag.c:1001 jtag_build_buffer(): fields[2].out_value: 0x00
Debug: ft2232.c:1181 ft2232_execute_queue(): DR scan, 36 bit, end in 8
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 25):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 1b 3b 05 09 6b 06 31 4b 06 25 39 03 00 02
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 00 08 00 3b 02 02 6b 06 31
Debug: ft2232.c:390 ft2232_send_and_recv(): read buffer (0 retries): 8 bytes
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 07 fc 00 00 00 00 00 fc
Debug: jtag.c:1032 jtag_read_buffer(): fields[0].in_value: 0x00
Warning: jtag.c:1074 jtag_read_buffer(): value captured during scan didn't pass the requested check: captured: 0x00 check_value: 0x02 check_mask: 0x07
Debug: jtag.c:1032 jtag_read_buffer(): fields[2].in_value: 0x00
Debug: ft2232.c:1102 ft2232_execute_queue(): runtest: 100, end in 8
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 45):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 00 4b 06 00 4b 06 00 4b 06 00 4b 06 00 4b
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 06 00 4b 06 00 4b 06 00 4b 06 00 4b 06 00 4b 06
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 00 4b 06 00 4b 06 00 4b 06 00 4b 01 00
Debug: jtag.c:274 jtag_call_event_callbacks(): jtag event: SRST released
Debug: ft2232.c:939 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: ft2232.c:1044 ft2232_execute_queue(): trst: 0, srst: 0
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 82 09 0f
Debug: ft2232.c:1189 ft2232_execute_queue(): sleep 150000 usec
Debug: ft2232.c:1102 ft2232_execute_queue(): runtest: 2030, end in 8
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 870):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 00 4b 06 00 4b 06 00 4b 06 00 4b 06 00 4b 06 00
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 4b 06 00 4b 06 00
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 16):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 25 39 03 00 02 00 08 00 3b 02 22 6b 06 31
Info: ft2232.c:375 ft2232_send_and_recv(): inter: 0.0, inter2: 0.0 end: 0.20000
Debug: ft2232.c:390 ft2232_send_and_recv(): read buffer (0 retries): 6 bytes
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): 13 50 26 49 49 fc
Debug: jtag.c:1032 jtag_read_buffer(): fields[0].in_value: 0x03
Warning: jtag.c:1074 jtag_read_buffer(): value captured during scan didn't pass the requested check: captured: 0x03 check_value: 0x02 check_mask: 0x07
Debug: xscale.c:789 xscale_load_ic(): loading miniIC at 0xfe000820
Debug: xscale.c:775 parity(): parity of 0xee1ade10 is 0
Debug: xscale.c:775 parity(): parity of 0xe21dd102 is 1
Debug: xscale.c:775 parity(): parity of 0x1a000001 is 0
Debug: xscale.c:775 parity(): parity of 0xe3a0d103 is 1
Debug: xscale.c:775 parity(): parity of 0xee0ade10 is 1
Debug: xscale.c:775 parity(): parity of 0xee1efe10 is 0
Debug: xscale.c:775 parity(): parity of 0x6afffffd is 1
Debug: xscale.c:775 parity(): parity of 0xee080e10 is 1
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x07
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x03
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x07f00041
Debug: ft2232.c:1181 ft2232_execute_queue(): DR scan, 33 bit, end in 8
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xee1ade10
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x00
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe21dd102
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x01
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x1a000001
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe3a0d103
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xee0ade10
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xee1efe10
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0x6afffffd
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xee080e10
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 126):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 2b 3b 05 07 6b 06 31 4b 06 25 19 03 00 43
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 10 00 fc 4b 06 b1 4b 06 25 19 03 00 10 de 1a ee
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 31 4b 06 25 19 03 00 02 d1 1d e2 4b 06 b1
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 01 00 00 1a 4b 06 31 4b 06 25
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 19 03 00 03 d1 a0 e3 4b 06 b1 4b 06 25 19 03 00
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 10 de 0a ee 4b 06 b1 4b 06 25 19 03 00 10 fe 1e
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): ee 4b 06 31 4b 06 25 19 03 00 fd ff ff 6a 4b 06
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): b1 4b 06 25 19 03 00 10 0e 08 ee 4b 06 b1
Debug: xscale.c:789 xscale_load_ic(): loading miniIC at 0xfe000840
Debug: xscale.c:775 parity(): parity of 0xee08ee10 is 0
Debug: xscale.c:775 parity(): parity of 0xe1a00001 is 1
Debug: xscale.c:775 parity(): parity of 0xeb000170 is 0
Debug: xscale.c:775 parity(): parity of 0xe1a00002 is 1
Debug: xscale.c:775 parity(): parity of 0xeb00016e is 0
Debug: xscale.c:775 parity(): parity of 0xe1a00003 is 0
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x07f00042
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xee08ee10
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00001
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb000170
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00002
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb00016e
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00003
Debug: ft2232.c:335 ft2232_send_and_recv(): write buffer (size 117):
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 83 10 00 fc 4b 06 b1 4b 06 25
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 19 03 00 10 fe 1e ee 4b 06 31 4b 06 25 19 03 00
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): fd ff ff 6a 4b 06 b1 4b 06 25 19 03 00 10 ee 08
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): ee 4b 06 31 4b 06 25 19 03 00 01 00 a0 e1 4b 06
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): b1 4b 06 25 19 03 00 70 01 00 eb 4b 06 31 4b 06
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 25 19 03 00 02 00 a0 e1 4b 06 b1 4b 06 25 19 03
Debug: ft2232.c:310 ft2232_debug_dump_buffer(): 00 6e 01 00 eb 4b 06 31 4b 06 25 19 03 00 03 00
Debug: ft2232.c:316 ft2232_debug_dump_buffer(): a0 e1 4b 06 31
Debug: xscale.c:789 xscale_load_ic(): loading miniIC at 0xfe000860
Debug: xscale.c:775 parity(): parity of 0xeb00016c is 1
Debug: xscale.c:775 parity(): parity of 0xe1a00004 is 1
Debug: xscale.c:775 parity(): parity of 0xeb00016a is 1
Debug: xscale.c:775 parity(): parity of 0xe1a00005 is 0
Debug: xscale.c:775 parity(): parity of 0xeb000168 is 0
Debug: xscale.c:775 parity(): parity of 0xe1a00006 is 0
Debug: xscale.c:775 parity(): parity of 0xeb000166 is 1
Debug: xscale.c:775 parity(): parity of 0xe1a00007 is 1
Debug: jtag.c:1001 jtag_build_buffer(): fields[1].out_value: 0x07f00043
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb00016c
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00004
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb00016a
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00005
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb000168
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00006
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xeb000166
Debug: jtag.c:1001 jtag_build_buffer(): fields[0].out_value: 0xe1a00007
ect
what could be wrong, could it be the the reset lines configuration or opencod simply does nt support pxa270 yet?
jacek
