OpenScale output to 7 segment display
I have an OpenScale board that I’ve used to log readings from a load cell. Now instead of logging readings, I want to display the (real-time) force on a 7 segment display. Is this doable with the OpenScale board and how do I go about implementing that?
AP
Yep - You’ll want to put an MCU in the mix as well to control the display…We have an example that uses our more basic load cell amplifier, 7 segment display, and an older esp32 board that you can use as a scaffold (it goes a bit beyond what you need though, you can skip the “Web Code” section)
For an MCU I’d look at SparkFun Thing Plus - ESP32 WROOM (USB-C) - SparkFun Electronics (it’s just a newer version of the one used above, should make thing a bit simpler…just be sure to select whichever you use in the Arduino IDE board selection tool)
Can you provide a link to the example you mention in your reply?
I meant to, oops! IoT Weight Logging Scale - SparkFun Learn
Thanks for sharing the ESP32 example. Putting an MCU between the OpenScale and the display makes a lot of sense, and a live readout sounds like a really neat use for it. Good luck getting it wired up!
