hello, all,
recently i got problem about a word about PCB array.
I know there are horizontal cutting and vertical cutting. But i want to know another way of cutting.
It is about cutting sheet into panel but the longer side of the panel is on the shorter side of the sheet.
It is usually used for single-sided PCB and double-sided PCB.
some people told me it is “cut by panel” and another people told me it should be named " horizontal and vertical cutting" .
I am quite confused.
Is there any one can help me?
Thank you!
[/img]
bigglez
2
global-pcbpartner:
Your earlier SPAM posts were easier to read,
and generally ignored.
Why do you return here?
bigglez:
global-pcbpartner:
i have deleted the signature. then it should not a spam.
I just want to know a word about cutting.
bigglez
4
global-pcbpartner:
Your signature was not offensive. Your posts were.
Why not open a new userID if you want to contribute
to this forum? Your current userID is being ignored
as it is associated with a Chinese SPAMmer…
