PGM-08278 Olimex arm-usb-ocd Windows XP install problem
After installing the s/w that came with PGM-08278 Olimex arm-usb-ocd on Windows XP and plugging in the Olimex JTAG pod, it makes it through installing (2) Olimex OpenOCD JTAG TINY installs. For the ARM-USB-TINY USB Serial Port install, it is looking for ftser2k.sys - I point it to ARM-USB-OCD-DRIVER\i386. When it is trying to copy ftser2k.sys to \Windows\System32, it blue-screens. Every time after that, it keeps wanting to install the same serial device.
I have used USBDeview to remove all Olimex OpenOCD JTAG Tiny’ devices to start over. The first (2) devices install fine, the serial always results in a blue-screen. Anybody have the same problem and were you able to get past it? I would appreciate any help.
