Pi Sense HAT
I’d like to design a mechanically similar HAT to the Pi Sense HAT. What height are the spacers, what’s the height of the extension header (looks like its included with the Sense HAT) and what are the dimensions/specs/part number for the socket that’s on the HAT?
Thanks for reaching out to us on this.
The standoffs are usually 11mm for Sense HATs; it uses a standard 40-pin GPIO header (entire board is about 1/2" tall).
For specifics on the Pi Sense HAT, we generally refer to their official site https://projects.raspberrypi.org/en/pro … -sense-hat , and I encourage you to consider some of our SparkFun product line to potentially simplify your setup, depending on your use-case: https://www.sparkfun.com/products/16301
Hope this helps, and happy sparking!
