Pin Map: Monster Moto Shield
Do you guys know where can I find the pin map for Monster Moto Shield? The data sheet has the pin map for the chips on the board only…
Thanks in advance,
Eddie
The schematic is here:
http://dlnmh9ip6v2uc.cloudfront.net/dat … ld-v12.pdf
The block in the lower left, called “ARDUINO SHIELDLABEL” represents the connections between the shield and arduino that is driving it. JP3 is the connector for motor power coming in to the board, and JP1 and JP3 are for the two motors. Those three are labeled on the board as to their pinouts.
/mike
Ouch forgot to check the scheme… thanks Mike!
