Hi guys,
I had discounted using the u-blox PointPerfect correction services as previously I read that it was localised. However, re-reading this today https://www.u-blox.com/en/technologies/ … 20seconds. it implies that there is a global PPP option.
Has anyone used this correction source with an Express or Facet to comment on setup and configuration? I guess I will need to use the RTK Express (with a decent antenna) as a Facet is not rugged enough to be used in a marine environment. Any info would be much appreciated.
