Hi everyone,
is it possible and advisible to power the I2S audio breakout board, i.e. the MAX98357A driver, directly from a LiPo battery?
Or should I add a LDO?
https://www.sparkfun.com/products/14809
Thanks and best regards
Felix
Hi everyone,
Felix
Hi Felix.
As long as your battery never exceeds 5.5 volts, and you’re ok with the board possibly acting strangely when the battery discharges below 2.5 volts, a direct connection to a single cell lipo would be OK.
If you want stable operation with a varying voltage, something like our [Buck-Boost Converter will give a steady 3.3 or 5 volts to the board and that would be a better choice than a LDO voltage regulator.](https://www.sparkfun.com/products/15208)
