I’m using tpl5110 power timer on my project successfully and it is a very usefull circuit.
(Circuit is attached)
i have double cheched it. The problem is that when battery has not reached the limit(fully charged), circuit works great and after some time arduino goes off and again on with the use of tpl5110.
But when it is in sunlight and battery is fully charged, somehow tpl5110 doesn’t goes off and stays on, untill i turn solar panel upside down(not charging…) and then in a minute power timer starts working as promised.
How can you explain it? What i have to do?
Thanks in advance…
