Pro Mini GPS Shield - TinyGPS++ error
Thanks for all the great products and examples!
I have used many without any issues.
My question is regarding the GPS-14030 Mini GPS Shield with microSD storage.
Using my just purchased ProMini328 and the before mentioned shield. I compiled and loaded the example code provided.
https://learn.sparkfun.com/tutorials/mi … okup-guide
Everything compiles fine, but I am not reading any data.
To debug I switched over to the TinyGPS library and data is being read correctly with no GPS CRC errors.
I’m using the simple_test.ino provided.
The code being used is cut and pasted from the Sparkfun website provided.
Any help would be greatly appreciated.
thanks in advance,
paul
Hi Paul.
I see that there is 2 different sketches on the hook-up guide:
Mini_GPS_Shield_Serial_Example.ino - Simply displays serial data in a serial terminal window.
Mini_GPS_Shield_Data_Log_Example.ino - Logs serial data onto the SD card using built in Arduino libraries. I presume you are using this sketch.
It does look like the code was originally written in 2016 for Arduino Version 1.0+. It looks like Arduino versions 1.6.8 - 1.8.0 were released back in 2016. If you are using a newer version of the IDE there is a possibility that some things may have changed in the IDE causing old code to not function properly in newer IDE versions.
Have you tried reverting back to a previous IDE version & tried to see if the code works?
