Hey guys, I am having a realy hard time getting my new sparkfun LCD to work with my AVR projects, if any of you have used the sf LCD+AVRs please help me out and look at my code, and my shematic and tell me if theres anything wrong:
http://temp.ph0rkeh.com/avr/lcd/ ← C Source and Makefile
(Uses peterflurys LCD lib)
http://temp.ph0rkeh.com/avr/lcd/shem.jpg ← shematic
The prob is All i am getting is a lit first line and the second line isent lit at all, I am away this is a sign that the LCD has not been initd… I have tested all my wires and they seem to be fine, I have even ran trace on my LCD with it taken apart and the db’s seem to enter the black epoxy were the chipset is, after that I cannot tell.
FYI: Im running on an atmega16 @ 4MHz crystal on 5volts - Codeing in winAVR libC GCC
edit: has anyone else had a prob with these LCD’s before? this is my first time using an LCD i normaly just use USART, but I would like to make some of my projects to be debugged away from a comp… I have tryed multiple source codes / examples and it doesent even flicker… just sits there like a tard ![]()
edit2: might also help uif you know what LCD im running its : http://www.sparkfun.com/commerce/produc … cts_id=790
blue on yellow 16x2 - hdd7 compat
