atmega8 + SF 16x2 RED/BLACK LCD + Peter Fluery’s library + avr gcc
Here is what I did so far:
Wired it up on PORTD (4 bit I/O mode)
Compiled Peter Fluery’s LCD library
Ran included test. Screen is black.
Triple checked wiring
Made startup delays longer
Checked fuses for default 1MHz
Googled, read all the results and verifed that the basics were covered
Rechecked wiring
Wired on PORTC
Recompiled with updated port defines
Coded up LED blinker as sanity check on ports d & c, worked fine
Breathed deep, let out slowly over teeth and started at 1 again
I am now pretty frustrated and need a way to verify the LCD actually works before I continue. The atmega8 has no JTAG fuse (common sighted issue for port not working) so I also need a fresh reason why this isn’t working assuming the LCD is healthy.
This is the exact wiring only mapped to the pins of PC0-6 on PDIP atmega8:
