Hello, I have an ADH8066 which is working fine so far. My issue is pulling a web page using GPRS. I have done the following:
AT+AIPDCONT=“internet” // edited as necessary with the correct APN, username, and password
AT+AIPA=1 // at this command I as assigned a private IP in the 10...* range
My provider gives me two other settings, but I’m not sure where to put them:
WAP IP 1 172.016.007.012
Wap Port 1 9201
At first I thought it was a proxy, so I attempted to pull a web page how you would do it using a HTTP proxy server. That gave a 304 socket error. So I tried to pull a webpage directly. Same 304 error.
Any ideas on how to use that IP address and port?
