Problem with A/D converter in XBee
How does the A/D converter in XBee 1mW Chip Antenna work? If I use 3.3 V at Vref I can measure the voltage of an analog signal in different interval. For example in 2.4 - 3.3 V the result from the A/D converter goes from 0 to 1024 and the same thing happens in other intervals.
In the documentation of the XBee there is a Vrefh and Vrefl how are these related to Vref?
I want to measure a signal between 1 and 2 volt with as good resolution as possible. How can i do this in a good way?
Thanks in advance and best regards.
just connect the analog signal to the A/D and use the AT commands to setup the sample rates, which network address gets the samples wirelessly, etc.
As per the OEM/User manual.
If I'm reading correctly, "XBee 1mW" is (was?) also known as the Series 1,
the Freescale-based unit from MaxStream. Last I heard (a year ago), the
ATAV (external VREF) command was inoperative, so Vref is always 3.3V.
In the Series 2.5 (“XBee 2mW”, I think?), the Ember-based unit from Digi,
there is also no VREF, but in that case Vref is always 1.2V.
In both units (as stevech says), you get ADC sampling using ATDn=2 .
