Hello, I have problem with STR911FM44 microcontroller debugging with OpenOCD 0.4.0, Eclipse and Amontec JTAGkey based programmer.
Here is the report from GDB:
Open On-Chip Debugger 0.4.0 (2010-02-22-19:05)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
RCLK - adaptive
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
Warn : str911.flash: nonstandard IR mask
Warn : str911.bs: nonstandard IR mask
Info : RCLK (adaptive clock speed) not supported - fallback to 10 kHz
Info : JTAG tap: str911.flash tap/device found: 0x04570041 (mfg: 0x020, part: 0x4570, ver: 0x0)
Info : JTAG tap: str911.cpu tap/device found: 0x25966041 (mfg: 0x020, part: 0x5966, ver: 0x2)
Info : JTAG tap: str911.bs tap/device found: 0x2457f041 (mfg: 0x020, part: 0x457f, ver: 0x2)
Info : Embedded ICE version 6
Info : str911.cpu: hardware has 2 breakpoint/watchpoint units
Info : accepting 'gdb' connection from 0
Warn : acknowledgment received, but no packet pending
RCLK not supported - fallback to 10 kHz
target state: halted
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x000000d3 pc: 0x00000000
RCLK not supported - fallback to 1000 kHz
cleared protection for sectors 0 through 7 on flash bank 0
Warn : NOTE! DCC downloads have not been enabled, defaulting to slow memory writes. Type 'help dcc'.
Warn : NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'.
Warn : memory read caused data abort (address: 0xe8a2b108, size: 0x4, count: 0x1)
And here is my linker script:
Program in flash memory
/* memory configuration */
MEMORY
CODE (rx) : ORIGIN = 0x00000000, LENGTH = 512K
DATA (rwx) : ORIGIN = 0x04000000, LENGTH = 96K
/* Sections definitions */
SECTIONS
/* section .text contains the code */
. = 0;
.text :
KEEP(*(.vectrom)) /* added by mthomas */
KEEP(*(.init))
*(.text) /* remaining code */
*(.text.*)
*(.glue_7t)
*(.glue_7)
*(.gnu.linkonce.t.*)
KEEP(*(.fini))
*(.gcc_except_table)
} >CODE
. = ALIGN(4);
/* section .ctors contains constructors */
.ctors :
PROVIDE(__ctors_start__ = .);
KEEP(*(SORT(.ctors.*)))
KEEP(*(.ctors))
PROVIDE(__ctors_end__ = .);
} >CODE
. = ALIGN(4);
/* section .dtors contains destructors */
.dtors :
PROVIDE(__dtors_start__ = .);
KEEP(*(SORT(.dtors.*)))
KEEP(*(.dtors))
PROVIDE(__dtors_end__ = .);
} >CODE
. = ALIGN(4);
/* section .rodata contains constants */
.rodata :
*(.rodata)
*(.rodata.*)
*(.gnu.linkonce.r.*)
} >CODE
. = ALIGN(4);
_etext = . ;
PROVIDE (etext = .);
/* section .data contains initialized data */
.data : AT (_etext)
_data = . ;
KEEP(*(.vectram)) /* added by mthomas */
*(.data)
*(.data.*)
*(.gnu.linkonce.d.*)
SORT(CONSTRUCTORS)
. = ALIGN(4);
*(.fastrun)
} >DATA
. = ALIGN(4);
_edata = . ;
PROVIDE (edata = .);
/* section .bss contains uninitialized data */
.bss :
__bss_start = . ;
__bss_start__ = . ;
*(.bss)
*(.bss.*)
*(.gnu.linkonce.b.*)
*(COMMON)
} >DATA
. = ALIGN(4);
__bss_end__ = . ;
__bss_end__ = . ;
_end = .;
PROVIDE (end = .);
/* Stabs contains debugger's sections */
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
.stab.excl 0 : { *(.stab.excl) }
.stab.exclstr 0 : { *(.stab.exclstr) }
.stab.index 0 : { *(.stab.index) }
.stab.indexstr 0 : { *(.stab.indexstr) }
.comment 0 : { *(.comment) }
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
So where is the problem? If you need any additional data, I will provide it.
