Here is the link where I bought the JetBot AI Kit for a school project: https://www.sparkfun.com/products/16390
I am running into some problem with getting the camera working after following all the steps in the tutorial. After installing all the parts following the tutorial and running the sample code, it works to control the basic movement like moving forward and backward and turning. However, it fails to recognize the camera. One of my other team members also purchased the same kit and he is able to get the camera working. From that, I double-check with him on the connection of the wire and it all seems correct. Any suggestion on what could be the problem or is it the Jetson Nano that is being faulty?
Also, there is another minor issue with the camera holder. The hole for the screw is a bit off for the holder, which unable to put a screw into it to keep the camera into the right place with the other parts. My team member who also bought the kit has the same problem.
