i am working interfacing the CC1100 with Atmel ATmega16 which is a 8 bit microcontroller. i have some problem while sending data in the TXFIFO and so i am not able to transmit the data can any one help me with this…
Why do you think that the problem is the TXFIFO? How do you do that? Use command stroke tx after sending the data into the TXFIFO.
Did you manage to make it work? I am having problems with my CC1101 modem so I would need your help. Talk to me if you are there ![]()
