Problem working on MP3 player shield
I’m using Arduino uno, a microSd shield and a Mp3 player shield
microSD shield: https://www.sparkfun.com/products/9802
Mp3 player shield: http://www.dynamodo.com/modules/arduino … hield.html
i’m having problems following this tutorial: http://efuller.net/blog/the-cats-meow
after uploading the code MP3Shield library demo to the microcontroller
the serial monitor display the ff. errors:
Can’t access SD card. Do not reformat.
No card, wrong chip select pin, or SPI problem?
SD errorCode: 0X1,0XFF
http://forum.arduino.cc/index.php/topic,116310.0.html
Google has all the answers.
the mp3 shield and sd card shield is now working, thanks. my next problem is that the mp3 shield only plays 1 sec of the mp3 file.
Searching “mp3 shield only plays 1 sec” brings up that it is likely to be your SD card. What card do you have?
i’m currently using SanDisk. I solved it by assigning the correct pins in the config file library.
