We have Amontec JTAG key working successfully with old open OCD (r717), I believe provided by Amontec.
We want to upgrade to latest openocd (for access to new processors), so got the V0.4.0 version from
http://download.berlios.de/openocd/open … .0.tar.bz2
We can successfully connect to the jtag key with the old open OCD, but not new.
Does anyone have any ideas what’s going on?
I have included logs of the sessions with the config files for the jtag interface, and contents of the files.
New openocd, new config file***
C:>openocd -f C:\sw_devel\OpenOCD\0.4.0\interface\jtagkey.cfg
Open On-Chip Debugger 0.4.0 (2010-02-22-19:05)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
Error: unable to open ftdi device: device not found
Command handler execution failed
Old openocd, old config file********
C:>“C:\Program Files\openocd-r717\bin\openocd-ftd2xx.exe” -f C:\sw_devel\OpenOCD\0.4.0\interface\jtagkey.cfg
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Error: ft2232.c:1419 ft2232_init_ftd2xx(): unable to open ftdi device: 2
Error: ft2232.c:1434 ft2232_init_ftd2xx(): ListDevices: 2
Error: ft2232.c:1436 ft2232_init_ftd2xx(): 0: Amontec JTAGkey A
Error: ft2232.c:1436 ft2232_init_ftd2xx(): 1: Amontec JTAGkey B
Old openocd open config file*******
C:>“C:\Program Files\openocd-r717\bin\openocd-ftd2xx.exe” -f C:\sw_devel\trunk\
common\moPhy3250_startup\lpc3250_jtagkey–hack.cfg
Error: jtag.c:1351 jtag_examine_chain(): JTAG communication failure, check con
nection, JTAG interface, target power etc.
Error: jtag.c:1556 jtag_init_inner(): trying to validate configured JTAG chain
anyway…
Error: jtag.c:1456 jtag_validate_chain(): Error validating JTAG scan chain, IR
mismatch, scan returned 0x00
Error: jtag.c:1565 jtag_init_inner(): Could not validate JTAG chain, exit
anyway…
Warning: telnet_server.c:624 telnet_init(): no telnet port specified, using defa
ult port 4444
Warning: gdb_server.c:2015 gdb_init(): no gdb ports allocated as no target has b
een specified
***************** New jtag config *****************
Amontec JTAGkey
http://www.amontec.com/jtagkey.shtml
interface ft2232
ft2232_device_desc “Amontec JTAGkey”
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
***************** Old jtag config file **************
#interface
interface ft2232
ft2232_device_desc “Amontec JTAGkey A”
