(sorry if this is a repeat, but I couldn’t find it)
Can you please recommend an appropriate set of arduino and bluetooth boards that will allow over-the-air programming of the arduino? Some of the products that look like they do this are out of stock and others don’t make it clear if they can actually program the arduino. I would like a 5v arduino of at least 16mhz that can be programmed via bluetooth, with bluetooth either onboard or as a separate but compatible product. I’ll be coming from MacOSX, if that matters.
