Trying to program a Sparkfun nRF52832 Breakout Board using “Tools/Programmer/J-Link” and then “Sketch/Upload using Programmer” on the Arduino IDE and get the following error:
embedded:startup.tcl:60: Error: Can’t find target/.cfg
in procedure ‘script’
at file “embedded:startup.tcl”, line 60
the selected serial port at file “embedded:startup.tcl”, line 60
does not exist or your board is not connected
Using a Segger J-Link LITE Cortex M programmer connected to the 10 pin debug connector on the breakout board.
The J-Link does program the nRF52832 board from Keil IDE however so hopefullythe hardware is okay.
Not able to use the Arduino bootloader as a function from the Arduino BLEPeripheral Library overwrote it so the bootloader is no longer operable.
Much appreciate any assistance.
