Burning Bootloader in NRF52832 Breakout Board
I have the NRF52832 breakout board and I connected J-Link to the Cortex Debug Connector. I’m using J-Flash and I can connect the the board. I want to burn the bootloader (I know that it came with it already). When I try to load sfe_nrf52832_dfu.hex I get an error message: “Error in line 1: not a HEX file”
Is this the correct file to load? What other way can I burn the bootloader?
A.
Just to state, due to this level of modification, SparkFun is unable to provide full support for this process. However, can you confirm what your setup is (i.e. what software are you using)?
