Programming standalone Artemis
I’m developing on an Artemis RedBoard. Once I get my code set and tested, how would I go about programming a standalone Artemis? Does SparkFun offer the Artemis shipped with my code installed or is there some other module I can use to program a standalone Artemis?
Hi Reg_Guy,
To get started with a bare Artemis module, I would highly recommend reading through our [Artemis Integration Guide. That will go over the module’s specifications including PCB footprint, pinout and reflow profile, as well as programming suggestions. The bare Artemis Module ships with both the Ambiq Secure Bootloader as well as the SparkFun Variable Bootloader to allow you to upload to it via a UART Bridge similar to the USB-to-Serial circuit on the SparkFun RedBoard Artemis. The other option would be to use a J-link programmer on the JTAG pins.](https://cdn.sparkfun.com/assets/8/7/5/3/f/Artemis_Integration_Guide.pdf)
