Im having issues with being able to automatically download to the IoT redboard. The only way I am able to is if i press the reset and program button which manually puts it into programming mode. Doesnt this board have onboard circuitry to do that automaticallly? I am using VScode with PIO
It does and the arduino IDE knows how to trigger it.
Sounds like the IDE you’re using doesn’t send a reset to the board at upload.
^Like he said; also:
Try using a different USB cable - sometimes cables that work fine for power/serial communication don’t reliably connect the DTR/RTS lines needed for auto-reset
Check your board’s upload_protocol in platformio.ini. For ESP32 boards, it should be:
upload_protocol = esptool
- Try explicitly setting the DTR/RTS control in platformio.ini:
upload_flags =
--before=default_reset
--after=hard_reset
- Manually set upload speed to 115200 (also in the ini file)
upload_speed = 115200
I added everything here beside the upload speed as when I do upload I see that it changes to
Changing baud rate to 460800
im still unable to get it to get it to automatically go into programming mode. Below is my .ini file
[env:sparkfun_esp32_iot_redboard]
platform = espressif32
board = sparkfun_esp32_iot_redboard
framework = arduino
lib_deps =
ottowinter/ESPAsyncWebServer-esphome@^3.3.0
knolleary/PubSubClient@^2.8
board_build.filesystem = littlefs
upload_flags =
--after=hard_reset
I’d guess it’s probably a setting in PlatformIO that needs to be set, then…or just push the button
I’m guessing you don’t have the right driver installed for the USB-UART chip on the board (CH340). I’ve experienced this behavior as well, and resolved it by updating the driver. It’s been a while since I’ve done that, and I recall that some versions of the driver don’t work properly. Try the one on our website, let us know if that works for you!
