Programming the LPC214x
When I try to program the LPC214x using IAR EW and a J-Link, the program goes to a hang position. I would like to know, whether there should be a boot-loader in place before programming the ARM through J-Link. What should I do if I have to program a bare chip, assuming the power and crystal are in place.
You must use the flash loaders.
In your IAR install dir search for the FlashLoaderGuide.pdf
