Project: Wearable Logger
Hi All,
New to this but have been doing substantial reading… I’m looking to create my own data/wearable logger that can log and export the following data:
Speed
Velocity
Time in Motion
G force
Here is my understanding of what I’ll be needing… I’m very interested in including the Intel Edison into it, so here are my preliminary thoughts:
Intel Edison w/ Mini Breakout Kit
Sparkfun Open Log
Sparkfun Venus GPS Logger
Sparkfun 9 Degrees of Freedom
Ion Battery
If the Edison has internal flash memory, can I use that to record the logged data? Or is the Open Log + SD card required? I basically want to capture the info from the GPS, Accelerometer and Gyro and be able to export the data afterwards. Where can that be stored?
The use I have in mind would be both indoor and outdoor, but will GPS (only used to measure speed, not actual plotting) work effectively enough if I’m only capturing speed data? My understanding is an accelerometer is good enough for just acceleration numbers.
Thanks for your input.
