Prototyping PCB supplier with RF/microwave suitabl laminate?
I’m looking for a low-cost PCB fab shop that supports Rogers R04350 laminate or something similar in terms of RF/microwave suitability. I found a supplier called “eurocircuits” that has a service called “RF Pool”; would like to find less expensive (per-setup, per-square-inch) alternative; OK going with asia supplier (not concerned much about turn-around time) if that helps cost considerations. My board requirements are, other than an RF-friendly laminate, very basic (double sided, plated through holes, 0.5-0.8mm thickness range.)
Any suggestions?
A quick search shows that Gold Phoenix and Sunstone both offer Rogers 4350. It’s not cheap, however. You can also get a 12"x18" sheet on eBay and etch it yourself; even that will be $60.
/mike
