I am not sure where to post this so I will go ahead and post it here. I am using a qre1113 breakout board from sparkfun…however my question is about the qre1113 in general. How do I get more sensitivity range out of this detector? I need a 5-7mm or 1-2cm high and if on a pcb board needs to be no more than 1cm wide. Do any of these sensors exist or do I have to make one with smd components or can the qre1113 sparkfun breakout board be modified to accomplish what I need? Thanks for the help - Scott
