Question about F25 package in Eagle
I’m looking at packages F25H and F25HP of the 25pin D-Sub connector part in the Eagle Sparkfun library. The only difference between the two packages (from what I can tell) is that one has pads for the mounting clips and the other doesn’t. Are the pads intended to be for grounding the connector? Is there any other reason for the difference?
-Dan
