do you know where i can find the footprint of this 9 way, PCB mounted, Sub-D connector?
Farnell 1099294
Farnell 1099294
Why not create your own? It only takes a few minutes with the software I use. The data sheet includes the layout you need!
Yes,
I am trying to create my own footprint…but the datasheet provided there does not have the details sufficiently forthe footprint.
I have been google’ing “Sub D , 9 way, 9/9, PCB Mounted, Socket, Footprint” but this also returns nothing.
I need to know the distance between the two holes, as well as the distance of the holes from the pins.
I am going to have to hazard a guess that the middle pin is bang in the middle of the part (as viewed from the front).
-but i’d rather see the footprint.
All the footprint dimensions you need are in the data sheet, see the second page.
right got it
thankyou very much!
If you are using EagleCAD, the standard library already has this part.
What CAD software do you want it for?
