Does anyone know of a good source of information on how to design boards with regards to electro - mechanical parts with enclosure design in mind. For example, how do you get the light from a surface mount LED out to a lens on the front faceplate of a product? How about a surface mount push button switch to a plastic button on an enclosure?
Design for Manufacturability is unfortunately an incredibly black art. You’d be best to talk to someone who has designed a similar product, disassemble something similar to what you’re designing, or to work directly with whoever your manufacturer is. The techniques you can use will depend on cost, quantity etc.
As for the specific LED question, if you can’t butt your LED directly against an opaque window, the normal technique is to use a transparent plastic light guide. It’s much like an el-cheapo fibre optic line.
If you must use a surface mount switch, get one with a long plastic push bit that will stick far enough out that it protrudes from the face plate, or use a separate plastic bit so the user can push it indirectly. Or maybe get a membrane switch pad manufactured. Again, it depends on too many factors.
tlynch99:
I have noticed that package designers are skilled in
My question is more about if you were going to use a prototype enclosure, with some cut outs, is there any information about how to interact with a surface mount push button by use of a mechanical part that connects to the enclosure and actuates the push button.
