I just bought a raspberry pi zero and some other stuff from http://www.w11stop.com/raspberrypi I’m using it for image processing.Can you please tell me that the camera used for raspberry pi 3 will also be compatible with pi zero or I will have to buy a new pi zero specific camera?
The Pi Zero has a smaller camera connector, so you will need an adapter cable: https://www.raspberrypi.org/blog/zero-g … connector/. Otherwise, it is compatible.
Thank u for your advice ![]()
