Hey, I’m working on this board for a project at my highschool, wondering if you guys could quickly look over my board to see if there is any obvious errors.
I wasn’t sure if the schematic i have is right, i am feeling as though the connection after the 4.7 k resistor off of pin 1 should go to pin one (VPP) of the ICSP header instead of VCC, what do you think? That’s why i left it, i can always just use a jumper…
I also didnt know the parts in my pcb program for the usb header or for the switches so i used pads and measured them out… they fit with the pads i have on this layout…
if you wouldnt mind taking a look that would be great!
I don’t have any experience with PIC’s other than an aborted first try a few years ago, so I’m not any help with this, but there are a lot of PIC people on http://www.electro-tech-online.com/ if you don’t get the answer you are looking for here, you can try that forum.
hi, sorry about that, it works now… just swapped hosts…
i am not looking for help so much with the internal workings of the circuit just more so a check to make sure my board matches the schematic, i am very new to this process…
Traxmaker is supposed to let you import netlists from Circuitmaker. I wasn’t talking about automatic routing, just ratsnest/nets and ERC. Check chapter 6 and page 13 of chapter 7 in this document to see what I mean: http://www.circuitmaker.com/pdfs/tm_usermanual.pdf
