Qwiic Cable connectors
Do you have a part number for the Qwiic connector - on the cable end - not the PCB connector.
As well, do you have part numbers for the hardware required to crimp them.
I have an application where I have to create a cable with a Qwiic on one end, and a different connector on the other. I would prefer not splicing cables together, so I am looking whether it would be worthwhile to make the cables myself.
If you look at the datasheet for the female connector : https://www.sparkfun.com/products/16766, you can see the mention of the part number (BM04B-SRSS-TB). Plug that into DigiKey and you can find the compatible products associate with this connector (crimp pins, housing, and such): https://www.digikey.com/en/products/det … -TB/759897.
Best of luck!
