Hi, I can only see a schematic on the website, do you have the datasheet for the kit?
What is the rated minimum temperature?
Also curious about minimum temp. for: USB-A to USB-C Cable - 1m, USB 2.0 (Flexible Silicone) - CAB-25630 - SparkFun Electronics
No…but these are just cables, you could likely expect them to perform well into the negatives…I’d guess -40c is fine for the bottom end (though note they would become fragile to movement!)
